AIMP Plugin Does not Work for Me
Started by danmeek
danmeek
09-04-2017, 04:17 AM -
I installed the AIMP version of the media control plugin. But when I click on the AIMP console, nothing happens.
This post was last modified: 09-04-2017, 04:30 AM by danmeek.
reddevil
5 posts 0 threads Joined: Sep 2010
10-03-2017, 11:37 AM -
(09-04-2017, 04:17 AM)danmeek Wrote: I installed the AIMP version of the media control plugin. But when I click on the AIMP console, nothing happens.
Make sure the dll is in the path: C:\Program Files (x86)\AIMP\Plugins\tlb_remote\tlb_remote.dll or wherever aimp is installed. Extract manually from the exe if needed.
danmeek
10-05-2017, 02:35 AM -
It is already there.
10-06-2017, 02:28 AM -
First, check if the plugin is listed in the AIMP plugins list. Then use the "Universal player" in the Media Control properties.
danmeek
10-06-2017, 03:27 AM -
I have done that. Still does not work. Clicking on it does nothing. But don't worry about it. It is not important to me.
I then rebooted and manually loaded AIMP. Then the plug-in works as a control of AIMP.
This post was last modified: 10-06-2017, 03:42 AM by danmeek.
mirol
3 posts 0 threads Joined: Apr 2019
01-03-2022, 01:34 AM -
I can anyone of you doing an update for that plugin. Aimp3 is very old. The actual Aimp Version is v5.01, build 2358. Thx
